Disables routing (or routing of broadcasts) for one or all VLANs. If no argument is provided, disables routing for all VLANs.
| broadcast | Specifies broadcast IP forwarding. |
| vlan_name | Specifies a VLAN name. |
Disabled.
Disabling IP forwarding also disables broadcast forwarding. Broadcast forwarding can be disabled without disabling IP forwarding. When new IP interfaces are added, IP forwarding (and IP broadcast forwarding) is disabled by default.
Other IP related configuration is not affected.
The following example disables forwarding of IP broadcast traffic for a VLAN "accounting":
disable ipforwarding broadcast vlan accounting
The ignore-broadcast and fast-direct-broadcast keywords were added in ExtremeXOS 12.0.
This command is available on all platforms that use the Edge, Advanced Edge, or Core license. For information on the licenses available for each platform, see the Switch Engine v33.1.1 Licensing Guide document.
